Cluster ActiveGate URL
Babar_Qayyum
Dear All,
We installed a Cluster ActiveGate long time before and then uninstalled but the URL is still available in the settings.
How to remove Cluster ActiveGate URL?
Babar
5 REPLIES 5
david_n
Inactive
Hello Babar,
Once you have uninstalled the ActiveGate it might take up to 72 hours for it to disappear from Dynatrace. For the url it looks like it can be edited and wiped out that way using the pencil icon beside it.
David Nicholls
Hello @David N.
Thank you for your comments.
Cluster ActiveGate was uninstalled 2 months before. I tired to remove with the edit button but it doesn't go anywhere.
e.g. after manual removal, click on X sign brings back the actual URL and click on Right Symbol gives the message of malformed URL.
Babar
I'm afraid your answer related to only Environment AG
Senior Product Manager,
Dynatrace Managed expert
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
hi @Babar Q.,
I'm afraid you can't remove Cluster AG URL. What's the use case or a reason you want to? I couldn't find any.
Hello @Radoslaw S.
May I know why we can't remove the URL even though there is no Cluster AG?
I want to remove because there is no real Cluster AG.
Babar
