hi All,
We used to face issue with Adobe CQ5 with Appmon Classc Java agents as the tags used to break the front end and as a wrokaround we used to add the beow flag
https://answers.dynatrace.com/questions/102959/dynatrace-cq5adobe-experience-manager-setup.html
com.dynatrace.diagnostics.alwaysUseReflectiveIntrospection Value = true
And we have seen similar issue with OneAgents as well. Does anyone else also faced similar issue with OneAgents?
Chetan
Answer by Rodrigo A. ·
If this problem is still happening, is better to contact support team and mention the debug flag you used in the past. You should not have access to place any debug flag in Dynatrace.
You can also consider to use Dynatrace Agentless RUM, in case the autoinjection is too intrusive in your application.
Best regards
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
