Easytravel Linux starting error
Shirai
Helper
I installed Easytravel-linux-x86_64-2.0.0.3025 on CentOS Linux release 7.6.1810 (Core).
Next, we introduced additional packages with reference to the following information.
Next, I ran runEasyTravel.sh, but the following error occurred and EasyTravel can not be started. I want to know how to deal with it.
[root@CentOS7-OSK easytravel-2.0.0-x64]# ./runEasyTravel.sh
starting easyTravel
2019-04-11 11:34:32 Launcher INFO [Init] -----------------------------------------------------------------------------
2019-04-11 11:34:32 Launcher INFO [Init] easyTravel Demo Application - Copyright (C) 2010-2019 dynaTrace software GmbH
2019-04-11 11:34:32 Launcher INFO [Init] Procedure: Launcher
2019-04-11 11:34:32 Launcher INFO [Init] Version: 2.0.0.3025
2019-04-11 11:34:32 Launcher INFO [Init] Build Date: Fri Sep 28 10:51:00 JST 2018
2019-04-11 11:34:32 Launcher INFO [Init] Platform: Linux 3.10.0-957.10.1.el7.x86_64, amd64
Exception in thread "main" org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
at org.eclipse.swt.SWT.error(Unknown Source)
at org.eclipse.swt.widgets.Display.createDisplay(Unknown Source)
at org.eclipse.swt.widgets.Display.create(Unknown Source)
at org.eclipse.swt.graphics.Device.<init>(Unknown Source)
at org.eclipse.swt.widgets.Display.<init>(Unknown Source)
at com.dynatrace.easytravel.launcher.SWTSingletonDisplayAdapter.init(SWTSingletonDisplayAdapter.java:33)
at com.dynatrace.easytravel.launcher.Launcher.run(Launcher.java:219)
at com.dynatrace.easytravel.launcher.Launcher.main(Launcher.java:185)
Stopping Engine because shutdown request was received.
T.Shirai IIM Corp. Osaka Japan
Rafal_Psciuk
Dynatrace Helper
Dynatrace Helper
Hi, runEasyTravel.sh script is starting configuration GUI application. If your system is headless it will not work. To run easyTravel on headless system use runEasyTravelNoGUI.sh or webaluancher/weblauncher.sh. The latter will serve nice configuration GUI on port 8094.
