Can we change the memory dump storage location on the server to an external path?
adam_sjoerdsma
Inactive
Hi team,
I have a customer that is wondering if there is a way to change the local storage path for memory dumps taken on a monitored host. According to them there is not enough disc space on the hosts to create memory dumps there. They want to know if they can create a symbolic link to an external storage location, and then have the ActiveGate retrieve the dump from there?
I know according to the documentation below, that we can change the storage path on the ActiveGate, but there doesn't seem to be anything on where the memory dump is initially stored on the monitored host.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/diagnostics/configure-an-activegate-for-...
Anyone have any experience with this issue and know how we can have the dump files initially stored externally to the host?
Adam Sjoerdsma
Enrico_F
DynaMight Pro
DynaMight Pro
