How Install ActiveGate plugin module
MAkimov
Mentor
Hello
Could anyone help with installetion ActiveGate plugin mode?
I use doc's instruction but help some misunderstanding https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-sdks/activegate-plugins/developmen...
I done:
1. Installed ActiveGate
2. Installed python3 and pip
3. Dowloade SDK and unzip it on ActiveGate
4. Installed SDK (used pip3 install plugin_sdk-version.whl)
5. Upload ActiveGate plugin
5. But have warning
You have no ActiveGate with ActiveGate plugin module running. ActiveGate plugin module is necessary to configure and run new plugin endpoint.
6. Upload plugin to server
Adn Use command oneagent_build_plugin -t yourtoken
But here I have error:
Plugin deployed successfully into /opt/plugin-sdk-1.163.277.20190318-125829/examples/demo_activegate_plugin/Hf0Qy_Q5SAqA1JBKuU-PA/custom.remote.python.demo
Plugin archive available at /opt/plugin-sdk-1.163.277.20190318-125829/examples/demo_activegate_plugin/Hf0Qy_Q5SAqA1JBKuU-PA/custom.remote.python.demo.zip
Restarting service
remotepluginmodule
Redirecting to /bin/systemctl restart remotepluginmodule.service
Failed to restart remotepluginmodule.service: Unit not found.
Error occured: Command '['service', 'remotepluginmodule', 'restart']' returned non-zero exit status 5.
How to run the plugin correctly?
There are no examples on this case in the troubleshooting section.
5 REPLIES 5
rodrigo_alvare1
Dynatrace Champion
Dynatrace Champion
On point 4 I think you have to copy the plugin to the folder plugin deployment before upload it:
Copy the ActiveGate demo plugin.
I do not have this folder /opt/dynatrace/remotepluginmodule/plugin_deployment
MAkimov
Mentor
understood
it turns out the collector must be installed with a flag
--install-modules
in the documentation for some reason not explicitly stated !!!
Could you please clarify where and when flag --install-modules should be used? I have the same issue
Same here... do we need to reinstall Active Gate for it?!
