Does Dynatrace SaaS Timeseries APi give me data region wise?
narravula_rohan
Newcomer
Trying to hit the timeseries AWS CPU usage metric API. I need region wise data in the response. Is it possible to add a filter or add any parameter that gives me this?
3 REPLIES 3
skrystosik
For TimeSeries API you will have only such parameters like in documentation:
https://www.dynatrace.com/support/help/extend-dyna...
I don't see any parameter that allow you to split results. Maybe it will be easiet to get those metrics directly from cloudwatch?
Regards, Sebastian
kulwinder_singh
Inactive
you can add a tag with region on the monitors and that should do the trick. then you can pull the data per tag
michal_nalezin
Dynatrace Advisor
Dynatrace Advisor
Hello Narravula,
As far as I understand, you are trying to use AWS EC2 CPU usage metric across multiple entities and group it by AWS region. This metric in expressed in %, so I would be careful with aggregation.
The idea to use tags seems to be a valid approach.
Best
Michal Nalezinski
Technical Product Manager
