Migrating the Appmon geolocation IP addresses to Dynatrace Saas
rswarnka
Helper
Hi, we are using appmon for the corporate application that span various geo-location and we have setup the IP mapping in the appmon. Is it possible to migrate the geo-location mapping from the appmon to Dynatrace Saas?
Babar_Qayyum
Hello @Rajesh S.
Yes. You can import custom locations.
Have a look on the below link.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/setup-and-configura...
Babar
Thanks Babar.
