Question about "install.bat" parameters
menda
Guide
Hi All,
Our customers plan to try OneAgent silent install on Windows servers.
MSI package includes batch file called "install.bat".
The file has following 3 parameters.
  1. PROCESSHOOKING="1"
  2. ALLOW_INFRASTRUCTURE_ONLY="1"
  3. ACTIVATE_HOST_GROUP="1"
What does these parameters use?
What happens if we change the values of these parameters?
Best Regards,
Masahiko Enda
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Masahiko,
These parameters are an internal implementation detail of the OneAgent installer and must not be changed. You can find the list of supported installation parameters, that you are free to modify, on the following help page: https://www.dynatrace.com/support/help/shortlink/...
Tomasz
Hi Tomasz,
Thank you for answering.
I understand the parameters.
Best Regards,
Masahiko Enda
