question
Mayana K. avatar image
Mayana K. asked ·
Kubernetes cluster integration with Dynatrace
I want to integrate the kubernetes AKS cluster with dynatrace. I have done for one cluster as per below documentation.
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/kubernetes/installation-and-operation/further-integrations/connect-your-kubernetes-clusters-to-dynatrace/
But the kubernetes url and token changes every-time when the do the deployment. I there any way to integrate the kubernetes using curl command?
so i can automate the process to run the command with the latest urls on the dynatrace servers to integrate.
Mayana Khan
Dynatrace Managedkubernetesazurecloud foundry
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
In configuration API you have such endpoints:
Dropdown menu on right top of your dynatrace console => configuration api and there you will see it ;)
Share
