ActiveGate plugin for Prometheus metrics
dhiraj_kumar
Newcomer
Following the blog :https://www.dynatrace.com/news/blog/dynatrace-monitoring-for-kubernetes-and-openshift/
At the last it says about a activegate plugin awaited. Has it been released. Where can I get an ActiveGate plugin for Prometheus metrics on Kubernetes?
skrystosik
There is Kubernetes tab in dynatrace. There is as well proper tab in settings where you can connect dynatrace to Kubernetes cluster:
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/kubernetes/installation-an...
Regards, Sebastian
