EasyTravel UEM load generator
chuan_sern_wong
Advisor
I would like to check on How to run the easyTravel UEM load generator in another separate machine ?
william_littlej
Dynatrace Helper
Dynatrace Helper
Hi Chuan,
This link will take you to a page which will have the latest version of EasyTravel available for download. There is a 'installation steps' section on this page too.
