Show Network Traffic utilization for containers created via Kubernetes
chuan_sern_wong
Advisor
As Kubernetes create containers in network mode, is there a way for OneAgent to support to provide Network Traffic usage per containers ? Futhermore, under Kubernetes, I don't see a any optiont for me to drill into each docker hosts/nodes and view each containers network usage too.
Any advise ?
Babar_Qayyum
Hello @Chuan Sern W.
  • OneAgent isn't able to report on an inter-docker connection if the containers use only the internal container's addresses (if the connection doesn't go through NAT vNIC).
  • Network statistics are reported for the main process detected inside containers hosted on Windows. This may lead to measurement inaccuracies when there are more processes performing network operations inside a monitored container.
Have a look on the below link for the limitation.
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/other-platforms/docker/mon...
Babar
