Remove unique elements from URI
melchor_brondog
Participant
Hi, I have several API's that take parameters from the URI.
Examples:
api/visit/1234566
api/visit/123456/create
So when I go to purepath or dynamic request I have hundreds of different request that are not grouped because of this parameters.
Is there any way in Dynatrace Managed to remove those parameters to group those request like so:
api/visit
api/visit/create
suresh230591
Mentor
Hi, I think web request renaming will work here. You can also use regex to specify condition.
Correct, this is the correct place to name your requests. If you have multiple services which need the requests to be renamed, you can also use global request naming rules.
