Use Ansible for auto-healing- restart app pools
I want to implement auto healing for a web service health/performance monitoring. If Failure rate increases to 100% for any services then Ansible should invoke the script to restart the app pool of the server which will have highest failure rate.
Can you please suggest is this possible? And how?
pahofmann
Yes that is possible. A good starting point to get into self healing with dynatrace an ansible would be Andi's Performance Clinic with Jürgen Etzlstorfer on that topic.
There also is a blog and documentation about the dynatrace ansible integration and self healing with it.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
