Free trial for dynatrace on-premise
suresh230591
Mentor
Could it be possible to get free trail of dynatrace for on-premise (like DT managed) so that we can create a cluster node and other cluster component on premise. This may help to understand the cluster node configuration, installation, un-installation , backup etc in a better way.
Suresh
3 REPLIES 3
himanshu_mor
Mentor
Hello Suresh,
Officially Dynatrace provides free trial for their SAAS version only as per below link
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/installation/set-up...
It says about installing from an activation link you receive via email.
This email is received by you only when you purchase DT Managed.
However you may talk to your respective Dynatrace Product manager (the one looking for your organisation from DT side) about the same and he may provide you some temp license as per requirement .
Himanshu Mor
Thanks Himanshu.
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Also see very similar topic here: https://community.dynatrace.com/questions/222275/hi-team-is-there-any-way-to-download-dynatrace-man....
Senior Product Manager,
Dynatrace Managed expert
