How can we control dtcookie ?
Yosi_Neuman
Hi guys,
Prospect application opens a new browser tab when clicking on a button.
The new/traget browser tab got a different dtcookie than the old/source browser tab and because of that ,we think, we see 2 separated session, 1 for the old the other for the new.
Is there a way to control this behavior in order to see in one user session the user actions from the old and new browser tabs?
Yos
skrystosik
I don’t think it is possible. Are you sure that this second browser isn’t timouted on dynatrace side? If yes it always be visible as ended one, new tab will be separate session.
Regards, Sebastian
Hi Sebastian
Thanks for your insight
Yos
