Dynatrace OneAgent monitoring Domain Controllers
anthony_kalind1
Participant
Is it possible to monitor Domain Controllers and DHCP servers on Windows?
I understand there was a user creation conflict problem prior to OneAgent v1.145.
Is it now supported with latest version and if so where can I find documentation on the details?
Anthony
Julius_Loman
DynaMight Legend
DynaMight Legend
Oneagent won't help you much on monitoring DHCP or other window services. You can use just process monitoring (if you can identify the particular process, some of the windows processes have unfortunately the same process name, thus you won't be able to distinguish them).
You can also use Oneagent plugins to fetch the information you need (for example from perfmon).
For these core windows services, deep monitoring is not an option, since they cannot be instrumented. Running oneagent in cloud infrastructure mode is sufficient in this case unless you run some processes where deep monitoring is possible and required.
andre_vdveen
DynaMight Champion
DynaMight Champion
Hi, the USER 'no_create' parameter must be used when installing on DC's - see here for details: https://www.dynatrace.com/support/help/technology-support/operating-systems/windows/installation/cus...
