Can I search for Entities there are not any tags?
tfukuda
Contributor
Hi all,
I have a question about tag.
In large environments, it takes time to check each Entities to see if it is tagged.
Is there any way to search?
Best regards,
Tomoko Fukuda
4 REPLIES 4
skrystosik
Hmmm i think this may be hard to do.
Only Idea I have is Environment API, there you can list all entities and check via script which of them has tags or not. You can make it via simple regex in sublime as well.
Regards, Sebastian
Julius_Loman
DynaMight Legend
DynaMight Legend
No you cannot. The only way is to use the environment API. For example to query services with no tags:
curl -XGET -H "Authorization: api-token $APITOKEN" "$TENANT/api/v1/entity/services"|jq '.[]|select(.tags=[])'
kulwinder_singh
Inactive
It can be done. Ideally i would do is pull the monitors data in a file using API and script and then in same script will parse the file for the required data without tags.
kulwinder_singh
Inactive
If you can do it fine otherwise let me know i will write something down for you.
