Dynatrace License Check Error
willie_liu
Participant
After install Dynatrace Managed (Install Server Success)
it shows License Check Error
sun.security.validator.ValidatorException: PKIX path building failed:
sun.security.provider.certpath.SunCertPathBuilderException
Something wrong?
We install with no Proxy
9 REPLIES 9
Julius_Loman
DynaMight Legend
DynaMight Legend
Is there maybe a transparent proxy between mission control and the Dynatrace server?
What is your output of the following command from the Dynatrace server:
echo |openssl s_client -showcerts -connect mcsvc.dynatrace.com:443
Does it show the following?
Server certificate
subject=C = US, ST = Massachusetts, L = Waltham, O = Dynatrace LLC, OU = GTG, CN = mcsvc.dynatrace.com
issuer=C = US, O = DigiCert Inc, CN = DigiCert SHA2 Secure Server CA
Yep it show,
but there is an error like :
verify error:num=19:self signed certificate in certificate chain
skrystosik
Now you are using proxy or you have traffic open wide to Mission Control? We have the same issue as you but with proxy. In our case, self signed certificate was overwrite by proxy to client one. We had to add client certificate (root + cer) to trusted according to this article:
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/configuration/how-t...
Check in your infrastructure if there is something that can overwrite your certificate and do steps according to link above.
Regards, Sebastian
It Stop at step 2, cause we cant create the cert as the step
Trust store is optional, you can skip.
Regards, Sebastian
Hi Sebastian
if skip how do i get the cert?
Willie
You need ask your security for certificate
Regards, Sebastian
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
That's a symptom of a communication issue to Mission Control. There has to be a transparent proxy in your network - probably firewall - as Julius writes.
Installer checks Mission Control connectivity and downloads license meta information to orchestrate self-monitoring OneAgent.
The error message comes from the JVM - so I assume it's the indirect output of the Server process.
I advise to open a support ticket so our team can make sure your installation works reliably and will help you with proper configuration.
Senior Product Manager,
Dynatrace Managed expert
i open a support ticket
ill wait Thanks
