How to deploy Dynatrace Agent on IBM Cloud Private (ICP)
we would like to deploy Dynatrace on our ICP cluster. We know ICP is based on kubernetes so we are trying to following this guide:
https://www.dynatrace.com/support/help/technology-support/cloud-platforms/kubernetes/installation-an...
Is it the correct one? We are trying to get the DT operator work on that but we have some trouble. Is it the correct documentation to follow?
Thank you,
6 REPLIES 6
skrystosik
What issues do you have? Any log messages, warnings? I’m not sure if ICP is supported in general. You can always start support ticket for this issue. But first of all you should be sure on which steps you have problems.
Regards, Sebastian
Hello @sebastian k.
Did you get any chance to work with the ICP cluster?
Babar
Not on commercial project, I'm making some experiments with small development on my own from time to time. ICP in general I have on my roadmap for near future in context of DT
Regards, Sebastian
Hello @sebastian k.
I received a requirement to start the monitoring of ICP. I thought you may have already done some work with the ICP platform, so I can get your assistance if required.
Babar
It was a matter of podsecuritypolicy. It seems ICP doesn't like the lines:
apparmor.security.beta.kubernetes.io/allowedProfileNames: runtime/default
apparmor.security.beta.kubernetes.io/defaultProfileName: runtime/default
when it comes to general ICP support, it is on the official ICP page:
https://www.ibm.com/cloud/private/partners
Hello @Davide D.
We are planning to instrument the ICP.
Is this fully supported by Dynatrace Managed?
Babar
