How does Dynatrace Synthetic judge availability?
menda
Guide
I have a question about Synthetic monitorinig availability.
Synthetic monitorinig has following errors.
  • Timeout(Script timeout: 5 minutes, Event timeout: 60 seconds)
  • HTTP status code 400-599
  • not found html element
I guess that when the website returns HTTP status 200 in time, Synthetic consider available.
If so, do we basically not need to set Validate content (text / element)?
Is this understanding correct?
Best Regards,
Masahiko Enda
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi @Masahiko E.,
yes - that's correct.
Kind regards, Philipp
There's always a chance that the site returns 200 OK but there's still an error message on screen. Of course if you know the site's behavior / how it's coded really well and are certain that something like this could never happen, then maybe the content doesn't need to be validated. But I would guess that in most cases you cannot guarantee that, and as such I would say it's a best practise to always have some kind of validation there.
