The message you are trying to access is permanently deleted.
11 Jun 2019 03:27 AM
Our customers will detect OneAgent errors by log file existing monitoring.
I have two questions about Abnormality of OneAgent.
Best Regards,
Masahiko Enda
11 Jun 2019 05:20 PM
Hi Masahiko,
Any "abnormality" that happens with the OneAgent would be logged in the OneAgent log files. They are stored by default at /opt/dynatrace/oneagent/log for Linux and ProgramData%\dynatrace\oneagent\log for Windows. I do not believe every possible kind of Anomaly is documented anywhere but you can take a look at your OneAgent logs to get a better understanding of your environment.
NJ
12 Jun 2019 08:03 AM
Hi NJ,
Thank you for your answer.
I understand this.
Best Regards,
Masahiko
