Prerequisists of Apache Tomcat for JMX Plugin
nkobayashi1
Helper
I'm trying to create JMX Plugin for Apache Tomcat.
But I can't find any Tomcat process in the source section of plugin editor.
The Tomcat process have not been rebooted after OneAgent installation.
So, I suppose that it is needed to reboot the Tomcat process to enable deep monitoring, then we will be able to create JMX Plugin.
Could you tell me whether it is correct?
Or, is there any Prerequisites for JMX plugin?
Noah Kobayashi
dave_mauney
Dynatrace Champion
Dynatrace Champion
My understanding is JMX metrics depend on the special agent, which means a restart would be required.
Thank you for your quick answer!
