Citrix NetScaler extension
michael_thiry
Participant
Hi ,
I try to use the citrix netscaller plugin.
In documentation i see 'Obtain the install file (custom.remote.python.netscaler.zip). Don't rename the file.'
Where is it possible to obtain this File ?
Ty
pahofmann
Have a look at @Obinna N.'s blog about the Plugin., it's mentioned there.
If you want to test the plugin either talk to the dyntrace ONE team via chat, or your sales representative.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
