Following an incident with One Agent Dynatrace using ports 50002 and 50003 dedicated to an application hosted on the server
pdesautels
Observer
I followed the procedure to configure another port: The Procedure is available on the Dynatrace website
https://www.dynatrace.com/support/help/technology-support/operating-systems/windows/operation/troubl...
the procedure is to edit the WATCHDOGUSERCONFIG .CONFIG file in C: \ Program Files (x86) \ dynatrace \ oneagent \ agent \ conf
in this file I indicate the desired port range:
Editing the watchdoguserconfig.config file works, Dynatrace uses the selected ports.
However, when updating the One agent Dynatrace the configuration of the WATCHDOGUSERCONFIG.CONFIG file disappears. The contents of the C: \ Program Files (x86) \ dynatrace \ oneagent \ agent \ conf folder are overwritten by the new version. It is replaced by the watchduguserconfig.conf.template file as originally
How can we fix this issue?
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Patrice,
you were editing the wrong file. You are supposed to edit watchdoguserconfig.conf , which is is located in the following directory: %ProgramData%\dynatrace\oneagent\agent\config
Tomasz
