Dynatrace API REST
alban_denizot
Contributor
The method GET request attributs is currently in beta therefore I understand that it is not 100% functional. Nevertheless when I execute the method the API fetchs 0 requests. Do I have to create custom request attributs ?
I thought that Dynatrace had built-in requests attributs ?
Julius_Loman
DynaMight Legend
DynaMight Legend
Do you mean the configuration API ? The /api/config/v1/service/requestAttributes endpoint?
This will, of course, return zero results unless at least one request attribute is configured in your environment. This endpoint is just an API for the UI in Settings > Server-side service monitoring > Request attributes.
Thank you for your answer I think that I understand now.
Thank you for your help !
