question
Jeff R. avatar image
Jeff R. asked ·
Are hogging or stuck thread metrics available in Dynatrace Managed?
I'm trying to determine whether Dynatrace Managed provides metrics equivalent to Hogging Threads and Stuck Threads for WebLogic. Somebody asked this question previously but no answer was provided. I.e., https://answers.dynatrace.com/spaces/482/dynatrace-open-qa/questions/208066/where-to-get-hogging-thread-count-in-dynatrace-man.html
Our monitoring users feel that having visibility to these two metrics will be very important. I do not see any metrics with these names, but I am hoping that something equivalent is provided without having to use a JMX plugin.
Dynatrace Managedjava
Sebastian K. avatar image
Sebastian K. answered ·
Hello, in default there is no such metrics, most you have is related to JVM, not WebLogic itself. You will need to use JMX plugin. Why is it issue for you?
2 comments Share
Using a JMX plugin results in the creation of custom metrics, which have licensing limitations. It would be far better if important metrics like these were made available out-of-box without the need to configure and manage plugins.
The MBean domain reference is com.bea and so the metric is part of the weblogic server runtime.... hence my reference to WebLogic.
0 Likes 0 · ·
From this point I agree. I suggest posting an RFE on forum to prepare such integration internally. In this way you will not consume custom metrics. But you always have some bunch of metrics free with your license. For each WebLogic instance you will consume 2. Depends of amount of instances it may be not so bad. But I agree that it should be covered like in many other technologies which are supported this way.
1 Like 1 · ·
Janne O. avatar image
Janne O. answered ·
We would actually also need this functionality covered without the need to use the JMX plugin and this should be covered as an out-of-the box metric in Dynatrace. It would be ideal if we could get this metric out on other java processes also and it wouldn't be tied to weblogic only.
I found the idea posted by Jeff so therefore I hope that every one who would need these metrics would vote for his idea.
https://answers.dynatrace.com/content/idea/223961/view.html
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX timestamp action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
