RabbitMQ - Multiple Clusters
richard_newboun
Newcomer
Hi
Is it possible to monitor multiple RabbitMQ clusters independently? We currently have 2 production clusters running slightly different versions and configurations of RabbitMQ. The plugin is grouping all nodes, reporting as the same cluster.
Is this possible / a planned future enhancement?
Richard
skrystosik
You can disable RabbitMQ plugin globally in Settings. Than you can enable it on each host separate. In such case you will have different settings on each host 🙂
Regards, Sebastian
