"Hide inactive" option selected always
jgarcianar
Contributor
Is it possible to keep selected "Hide inactive" option on Smartcape Topology always? I mean, I could "Show inactive" when I desire, but I don't want to see 3 thousand of Candidate hosts that below to one VCenter always I connect, for example, and almost all are inactive.
skrystosik
There is no such possibility, but you can always create management zones and use them as a filter. You can for example create one that will contains all monitored entities. This should be enough 🙂
Regards, Sebastian
