Private Browser with Proxy
Dant3
Pro
Howdy all!
Did anyone try this new mode in Dynatrace?
Is there any way to avoid sending the screenshots at AWS and use it locally? Or setting the proxy?
I can't found the correct way to do that setup. Did anyone managed to doit? (Proxy without Auth). Host reach the localwebpage, wget to the adress download the correct index file). But the output of the synthetic player is timeout reaching the web.
Thanks!
Services Solution Engineer @PowerCloud - Observability/CloudOps Certified / Former SE @Dynatrace.
andre_vdveen
DynaMight Champion
DynaMight Champion
