Dynatrace SaaS integration with Dynatrace Managed
suraj_gupta3
Participant
We have a requirement where we are looking to integrate Dynatrace cloud-based solution with our on-premise Dynatrace Managed server where the requirement is to push data from the cloud solution to on-premise solution.
If the above integration is possible then what kind of content can be pushed to managed server?
Primarily we're focusing to transfer RUM, OneAgent and Synthetic data from cloud to managed server.
Your quick reply would be appreciable.
skrystosik
You cannot connect cloud and managed as HA to transfer data. Such operation is possible only between managed nodes. What you can do is extract configuration from managed via configuration api and push it to SaaS in the same way. There is no option to transfer data (at least I don't know any).
Regards, Sebastian
Thank you Sebastian, I've raised a support ticket as well.
Suraj Gupta
