Running Processes detected - Shell Scripts
ajdimanuel
Inactive
yesterday in a meeting a customer asked me if OneAgent is able to detect shell scripts running in a machine. These shell scripts launch PL/SQL code and the need to capture basic information of these processes (CPU, Memory, I/O, etc). I'm not sure if Dynatrace is able to capture these kind them.
Thanks in advance.
Alberto.
3 REPLIES 3
skrystosik
Not by default, it may be possible writing custom integration via OneAgent SDK. You will see at least new process running on machine but without pureparths.
Regards, Sebastian
I don't need PurePaths, just to see the process consume of HW resources. In Windows I am able for example to see Chrome processes.
Alberto.
From such point of view when you will display cpu breakdown on host you should be able to see it
Regards, Sebastian
