How to map RUM endpoints to Entity IDs?
runfast
Newcomer
What is the best way to map my RUM tracked endpoints to entity IDs so I can query them from the API? Is there an endpoint that gives the mapping that I can hit?
I am tagging our endpoints so they have logical names, however I don't know the best way to get the related Entity IDs.
My goal is to use these entity ids to query the timeseries endpoints for response time data.
Hitting the endpoint without a list of entities gives me a list of entities, but I am unsure of what is determining what is showing up in that list. Is that just a top list based on some metric? Is it the "Key User Actions", and if so, will all of them show up there regardless of the number of Actions I set as "Key"?
skrystosik
I think easier option would be writing script that has definitions of all entities from your tenant, and then you will be able to use this as reference during playing with RUM api endpoint.
Regards, Sebastian
