How to capture code level instrumentation docker service
jibi_uthaman1
Participant
We have one agent enabled for host and it is showing some details on the docker containers. But code level details is not captured for the service. What needs to be done to enable that?
Automatic container injection for deep monitoring for Docker containers is enabled.
skrystosik
What is technology of service inside container? If it is for example raw java or raw .net, you will need creating custom service:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/services-and-transactions/configuration/...
Regards, Sebastian
