What Happened To Slack Integration Attachments?
When we add the official Slack integration from the Set Up Notifications Screen, this is the type of post that is sent:
There are no attachments in the notifications in Slack. But from whaat I'm seeing in various Q&As, there used to be. Why is there no longer any attachments? I find the attachments extremely useful, particularly if there can be a button, "View In Dynatrace" rather than just title links.
See these threads:
https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/215534/configure-slack-attac...
https://community.dynatrace.com/spaces/482/dynatrace-open-qa/questions/207304/slack-itegration-json-...
https://community.dynatrace.com/spaces/482/dynatrace-open-qa/questions/196177/dynatrace-saas-davis-i...
3 REPLIES 3
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Good question I will check and create a bug in case. Did you ever tried the much newer Davis Assistant Slack integration? It offers a much more convenient feature set and interaction possibility as well as attachments and it comes for free for all Dynatrace environments.
https://www.dynatrace.com/platform/aiops/davis-assistant/
Adding Davis Assistant solved the problem. I am not totally happy with the attachments that Davis provides, but it's way better than the other integration.
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
@Ian C. did you also check if the attachments are correctly shown for real problems coming in, not just the test run that contains no real data?
