OneAgent Plugin: How does the new "metricGroup" key effect?
nkobayashi1
Helper
We've noticed that the new key is added to the Plugin.json of OneAgent Plugin as required key.
https://dynatrace.github.io/plugin-sdk/api/plugin_json_apidoc.html#metadata
We suppose that the "metricGroup" key effects only to the Custom Chart screen.
Could you tell me whether it is correct?
Background:
We have just released the new plugin before v1.172 release. So we have to re-test to our plugin. We want to check how the change ( metricGroup) effects.
Noah Kobayashi
Jakub_Mierzewsk
Inactive
Hi.
Impact is broader. All metric keys all calculated based on metric group.
Thanks to this data to a metric can be sent from different sources like REST API or different types of plugins.
Jakub
