Plugin settings per host, but not alert settings?
tarjei_utnes
Organizer
So I am able to configure the properties for custom plugins on a per host basis (by disabling globally, and enabling per host)
But I cannot see that this is possible for the Plugin events?
4 REPLIES 4
tarjei_utnes
Organizer
Got an answer from support chat, that it is currently not supported.
Thank you, Tarjei, for getting back with the answer!
Keep calm and build Community!
I've created an RFE about this. Please upvote if you think this is needed:
https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/232446/rfe-allow-plugin-even...
As commented by Wolfgang Beer in my RFE, these can be manually defined as custom events.
