API for Reports
To create some custom reports for certain stakeholders I would like to pull a high-level health report from Dynatrace. The aggregated data from the default report would make an easy source and gives a broad health indicated. It would be nice if those would be available trough an API / Timeseries.
Are they?
skrystosik
There is no such API right now, only metrics from timeseries are available. So in general only option would be building requests with data you need and asking it one by one.
Regards, Sebastian
Julius_Loman
DynaMight Legend
DynaMight Legend
I'd recommend to see a replay of the webinar (Dynatrace Reporting Through the API) if you need to build your custom reports (in a 3rd party tool). It gives you examples how to easily pull timeseries and other data via Dynatrace REST API.
See the replay here https://university.dynatrace.com/ondemand/dynatrace/21409/22543
