Contribution per service graph
Hi, is there an option to have a contribution per service graph? For example in the Multidimensional analysis views? I really like the insights you get with service flow - but sometimes it would be nice to see how the contribution per service changes over time.
4 REPLIES 4
skrystosik
There is no such option right know. If uri is the same between propagated services it would be best I think using Diagnostic tools => Top Web Requests. There you will be able filter the same uri across multiple services. But this will not work in all situations and it's rather workaround than solutions.
Regards, Sebastian
Julius_Loman
DynaMight Legend
DynaMight Legend
This is achievable by using the Service metrics definitions. (Currently available in EAP only). There you have the options to measure metrics such as time spent in calls to other services. You can also define the dimension for this metric which sounds exactly what you need.
Currently available metrics are:
Service metrics:
  • Response time
  • Request count
  • Successful request count
  • Failed request count
  • Error count
  • Failure rate
  • HTTP 4xx count
  • HTTP 5xx count
  • CPU time
  • IO time
  • Wait time
  • Lock time
  • Number of calls to databases
  • Time spent in database calls
  • Number of calls to other services
  • Time spent in calls to other services
Client-side metrics
  • Response time measured by caller
  • Successful request count as seen by caller
  • Failed request count as seen by caller
  • Failure rate client
  • Number request attributes
That’s the one
Regards, Sebastian
