Is server based URL monitoring possible ?
haiders
Inactive
Hi All,
I have a question regarding availability check for my application URL.
I need to provide availability check for few URLs which are running on 10 different server behind the Load Balancer [LB], its the LB that decides which URL will be running on which servers.
the case here is suppose for 9 out of 10 servers all my URL are working fine but for one server few URL aren't working & we want alert for that server.
Is it possible to generate alert based on the non availability of URL on particular server via synthetic monitoring or any other mode?
Julius_Loman
DynaMight Legend
DynaMight Legend
Yes you can set up synthetic check for the URL using the Environment ActiveGate. However, the ActiveGate should be running on a dedicated host and needs to have direct access to the hosts and URLs to be monitored.
Still - it's just a synthetic test. I don't know your particular use case, but you have a oneagent on the problematic host and depending on the URL/requests, you can just set up alerting on your particular requests.
