question
Alfredo S. avatar image
Alfredo S. asked ·
EasyTravel-Docker on differents instances AWS
Hello, I would like to run two EC2 instances of AWS, one with a docker with the easyTravel application and the other with the loadgen docker/service.
In the future I would like to run each service of the docker-compose.yml of the image in different EC2 instances and then install the OneAgent in the correct instance.
The problem is that I don't know how to do it very well.
Any help or guide is welcome.
Thank you.
installationdockeramazon web services
1 Answer
Chad T. avatar image
Chad T. answered ·
If you still need assistance with this, I would recommend opening a support ticket as this question was asked a year ago and there has been no comments. If you have solved this question, please let us know what you did in order to solve the question asked.
Thank you,
Chad
Share
