Using custom header instead of x-dynatrace
Anonymous
Not applicable
Can we configure one tenant of dynatrace SAAS to use a custom header instead of x-dynatrace
We already have a header for end to end traceability, It is not called x-dynatrace though
skrystosik
But your own header has different structure then dynatrace one. So even if you have it it will not work at all (even if it will be possible changing the name, which is not).
Regards, Sebastian
Anonymous
Not applicable
Thanks.
If the header is not customisable, then the question of structure does not arise.
Our is Unique, I thought that is all that is required for tracing a txn end to end.
