Pricing for AWS ECS Fargate Docker containers monitoring
quentin
Participant
We are about to migrate some of our docker containers from an on-premises host to AWS ECS with a Fargate deployment.
How does Dynatrace billing works in this case, since the agent will be installed in the containers and not in the host ?
Thanks !
3 REPLIES 3
skrystosik
You should contact with Dynatrace sales or partner in your country about it.
Regards, Sebastian
Thanks! I did that and posted their answer.
quentin
Participant
I asked Dynatrace's support through the in-app chat. Here is their answer:
When doing the Fargate Deployment, we're simply downloading and installing the agent through the build script. This would mean that Host Units would be charged by the RAM dedicated to each Docker instance. https://www.dynatrace.com/support/help/shortlink/monitoring-consumption#host-units
So each container counts for a host, using host units according to the allocated RAM:
