Disable alerts from 404 errors
alexandre_fedi
Participant
Actually we receive alerts (like "failure rate increase") from http 404 errors. We don't want to disturb our ops teams with that kind of alert because it's not a "real" error for us, it's a client side problem (a wrong url may cause this). So we just want to disable problem alert, but keep the problem detection in Dynatrace).
Can you help us to make the right set up ?
Thanks per advance 🙂
Kind regards
skrystosik
you Can’t but if failure rate because of 403 is constant, DT should stop alerting after some time.
Regards, Sebastian
