Does Dynatrace support AWS SNS PurePath Tracing?
I know there is an Early Access Program for AWS Cloudwatch Extended Services monitoring but is there any plans to trace through AWS SNS?
Looking for a capability similar to this: https://aws.amazon.com/about-aws/whats-new/2019/07/amazon-sns-adds-support-for-aws-x-ray/
4 REPLIES 4
skrystosik
I don’t know anything about such eap right now. You can post RFE for such functionality.
Regards, Sebastian
Hi Sebastian,
I was referring to the EAP mentioned here: https://www.dynatrace.com/news/blog/aws-supporting-services-eap/
I will raise an RFE like you suggested. Thanks!
SNS mentioned there will give you only metrics from cloudwatch, not purepaths unfortunately.
Regards, Sebastian
aiden_senner
Newcomer
I am also interested in this. I have a client that will be moving from JMS TIPCO to AWS SNS and will need purepaths. I would like to see if we can help in this regards.
