29 Jul 2019 02:29 PM
on the Liferay landing page, there is a fastpack mentioned:
https://www.dynatrace.com/technologies/liferay-monitoring/
I am wondering, is there a Liferay fastpack for Managed? I can only find one for AppMon.
15 Jan 2020 07:33 PM
In dynatrace managed there no something like fastpack you can use except JMX plugins. Most of mentioned on those pages technologies has out of the box metrics definitions. After instaling agent should work out of the box (if they don't need extra configuration).
I will be doing POC on Liferay soon so I'll check it by my hand 🙂
