question
James Y. avatar image
James Y. asked ·
Session Replay -- How to view?
I've enabled session repllay -- but can't find where to view a session in the UI? I select a session but it does not provide me any way to replay it? ust be missing something...
Cheers,
session replay
Sebastian K. avatar image
Sebastian K. answered ·
Go to User Sessions. On filter on top pick Session Replay => Yes. Than you will have all sessions that has proper recording available. When you go to such session you will see play button for whole session or for each action of it separate.
Share
Simon S. avatar image
Simon S. answered ·
@James Y. if not all sessions have session replay, then this is either a) due to not all applications having Session Replay enabled and/or b) due to cost control settings that will lead to recording only a sub-set of all sessions. So if you want more sessions to be recorded, just change these settings accordingly.
Share
James Y. answered ·
Tx.. Just evaluating this.. Apologies for the easy questions :-) Next up will be Conversion goals
1 comment Share
This is what this forum is for :-)
1 Like 1 · ·
