question
Axel V. avatar image
Axel V. asked ·
NetIQ Access Manager monitoring with OneAgent full stack
i'm trying to monitor NetIQ Access Manager and i'd like to know if full stack OneAgent is supported or if there are some incompatibilitie.
This software is running on SUSE Enterprise Linux 11.4 (x86).
Someone has already tried to monitor this NetIQ Access Manager?
Axel
configurationmonitoringsso
1 Answer
Chris G. avatar image
Chris G. answered ·
Hi Axel,
Dynatrace supports technologies. More information can be found here:
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
Suse Enterprise Linux 11.4 is supported.
NetIQ is partly Java (Tomcat and Java processes) and can be monitorred with Dynatrace. Some parts are maybe C-Code and will be less visible. Let us know your results.
Kind regards,
Chris
1 comment Share
Thank you Chris. I'll try to monitor it.
Kind regards,
Axel
0 Likes 0 · ·
