question
Wai C. avatar image
Wai C. asked ·
Azure Monitor Integration didn't return the Memory Usage, but only CPU.
As you can see, the 'Used Memory' Column has no value but 'no OneAgent', is this expected?
Normal question rise from this screenshot would be "Why I see CPU but no memory?"
Best Regards,
Wai Keat
monitoringazure
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
I have similar questions on support related to missing metrics on CloudWatch on AWS. Dynatrace is presenting only data that are returned from api. So questions are two, if there are any settings that are configuring integration scopes? If not, try using postman to ask azure api for data and check if memory metrics are there. If not, it is question to Microsoft team. If yes, rise support ticket.
Share
