question
Thanes B. avatar image
Thanes B. asked ·
Are other monitoring tool Events integration possible with Dynatrace for Incident Correlation?
We are trying to leverage DT AI engine event correlation capability as central point for many of other monitoring tools such as; SevONE, SCOM, NetCool, ICINGA, OEM ETC
Does DT have integration mechanism for these tools to collect metrics/events so they can be used by DT AI engine for problem identification, RCA, event correlation ETC?
alertingauto-detectionnotifications
Wolfgang B. avatar image
Wolfgang B. answered ·
As Julius already mentioned, you can send in events to existing entities, such as host, services, etc. The mapping to an existing host should be pretty easy, while for the mapping onto a service you most likely will use a tag based approach.
The idea behind sending external events into Dynatrace is to provide some additional context information or more root cause info.
I agree that it does not make much sense to send in additional metrics or events that Dynatrace already collects and alerts on anyway.
Best greetings,
Wolfgang
Share
Julius L. avatar image
Julius L. answered ·
No. Not at the moment. Albeit this is technically possible. it basically boils down to properly sending events to correct entities in Dynatrace and of a correct type. This sounds easy, but each monitoring tool has different concepts and entity types. Proper event integration between any monitoring tools is almost always a pain.
However, ingesting just a subset of clearly defined events seems possible, although I'm not sure if there is any benefit. Events in Dynatrace must be sent to an existing entity (Application/Service/Process/Host/...) and you can't create entities of those types (just custom devices). Also, I don't think it makes sense to run multiple monitoring tools on the same hosts and do an event integration. I'd consider a replacement of those legacy tools where Dynatrace is already in place.
Don't forget this event ingestion works only with AI2.0 which is not the default yet.
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
